AnnetteL
Sep 06, 2025Star
Nighthawk M6 Pro Ethernet port
After recent automatic update, Ethernet port on nighthawk M6 Pro not working. Can toggle it on/off, but has no output signal. Any troubleshooting suggestions?
ntweather
Sep 08, 2025Tutor
After much complaining I got ATT to send me a new M7 to replace this M6. Will keep you updated, but hoping this will be a fix for me.
deuxcv
Sep 08, 2025Star
any tips on getting them to replace your m6 with m7?
do you happen to know if the update at fauld was from att or Netgear?
- bigbadbirdSep 09, 2025Tutor
deuxcv I'm certain it was the most recent firmware up update.
- KJMJFLSep 09, 2025Guide
Same here. NEVER had a problem with the MR6500 until immediately AFTER the firmware was upgraded! AT&T should have tested this BEFORE releasing it to their customers! We need to bombard them with demands so they escalate this!
- ntweatherSep 10, 2025Tutor
new m7 works perfect, updated to current firmware. actually works better and better speeds than with the m6. would suggest calling and threaten to cancel your account thats how I got mine.
