AnnetteL
Sep 06, 2025Star
Nighthawk M6 Pro Ethernet port
After recent automatic update, Ethernet port on nighthawk M6 Pro not working. Can toggle it on/off, but has no output signal. Any troubleshooting suggestions?
jgoode27
Sep 09, 2025Initiate
I have two of these devices through AT&T. Both installed the update on Friday and the ethernet on both has stopped working with the same symptoms as mentioned here. I have been through settings and tried multiple things but the most I can do is get it to work for a couple of minutes before stopping again.
WesC
Sep 09, 2025Tutor
It is so frustratingly obvious that the issue is the new firmware and no way to back out to the old firmware. Plus have you tried to get ahold of ATT tech support? What a joke that has been.
