AnnetteL
Sep 06, 2025Star
Nighthawk M6 Pro Ethernet port
After recent automatic update, Ethernet port on nighthawk M6 Pro not working. Can toggle it on/off, but has no output signal. Any troubleshooting suggestions?
Sally20_GO
Sep 09, 2025Tutor
During my weekend tests of Firmware 1.2.1, I observed that the problem stemmed from the WLAN channel. Speeds were unstable on channels 52-64. Channels 36-48 showed no problems. Until now, I'd been using channels 52-64 because they weren't used in my area. Unfortunately, since I couldn't revert to the old firmware, I started using channels 36-48.
- JoenembaSep 10, 2025Guide
Are you saying the ethernet is fixed on different channels? Pardon my ignorance, but how do you change this exactly?
