AnnetteL
Sep 06, 2025Star
Nighthawk M6 Pro Ethernet port
After recent automatic update, Ethernet port on nighthawk M6 Pro not working. Can toggle it on/off, but has no output signal. Any troubleshooting suggestions?
AnnetteL
Sep 10, 2025Star
Tried to set up as StevenL1 suggested (go to bridge mode and connect Ethernet to WAN on router). No joy for me. Could connect wireless but was unable to actually load any pages.
Installed refurbed MR6500 that came in today and all works as should. If there's ever a fix for this issue, I'll have a spare MR6500.
- StevenL1Sep 10, 2025Guide
Sorry to hear it didn’t work for you with the ethernet to router in bridge mode. I just have a cheap TP link router from walmart
Glad to hear you’re back up and running with a new M6 though. Does it have the same firmware as the old? Going to be trying to call again tomorrow to see if I can finally connect to somebody
- AnnetteLSep 11, 2025Star
Not sure the version of firmware on the new M6. Once we had it up and running, didn't want to tink with it anymore.
We tried using a Linksys router that we no longer when we tested bridge mode. Not sure why it didn't work for us.
We'll see if another firmware version gets pushed out on this M6. Fingers crossed.
- DarrenMSep 11, 2025Sr. NETGEAR Moderator
Hello Everyone
We have a known issue with the M6. You can find the workaround here https://community.netgear.com/discussions/aircard/nighthawk-m6--m6-pro-connectivity-issue/2465491
Thanks
DarrenM
