AnnetteL
Sep 06, 2025Star
Nighthawk M6 Pro Ethernet port
After recent automatic update, Ethernet port on nighthawk M6 Pro not working. Can toggle it on/off, but has no output signal. Any troubleshooting suggestions?
StevenL1
Sep 10, 2025Guide
Sorry to hear it didn’t work for you with the ethernet to router in bridge mode. I just have a cheap TP link router from walmart
Glad to hear you’re back up and running with a new M6 though. Does it have the same firmware as the old? Going to be trying to call again tomorrow to see if I can finally connect to somebody
AnnetteL
Sep 11, 2025Star
Not sure the version of firmware on the new M6. Once we had it up and running, didn't want to tink with it anymore.
We tried using a Linksys router that we no longer when we tested bridge mode. Not sure why it didn't work for us.
We'll see if another firmware version gets pushed out on this M6. Fingers crossed.
- DarrenMSep 11, 2025Sr. NETGEAR Moderator
Hello Everyone
We have a known issue with the M6. You can find the workaround here https://community.netgear.com/discussions/aircard/nighthawk-m6--m6-pro-connectivity-issue/2465491
Thanks
DarrenM
- JR314Sep 13, 2025Guide
DarrenM, I noticed that when I go to the page listed above, replies are turned off so I'll ask here. It indicates Netgear engineers are working on the problem.
Was this a Netgear update that caused the failure? Can we revert to the previous firmware version? Any ETA on a fix? Neatgear support blamed AT&T and AT&T said it was a Netgear update. Who's not being truthful? Thanks.
- deuxcvSep 13, 2025Star
I got an update yesterday afternoon but had to leave so didn't have time to take out of bridge mode and test.
