AnnetteL
Sep 06, 2025Star
Nighthawk M6 Pro Ethernet port
After recent automatic update, Ethernet port on nighthawk M6 Pro not working. Can toggle it on/off, but has no output signal. Any troubleshooting suggestions?
StevenL1
Sep 11, 2025Guide
You should give us the option to rollback previous firmware, or just roll it back for us and make everybody happy while you guys take God knows how long to get another update out to fix the issue at hand. Thanks
- JR314Sep 13, 2025Guide
I talked to AT&T again today. They still have no update, but said to check back next week. They said it was a NETGEAR update and NETGEAR is working on a solution. I asked about rolling back and they were told an Ethernet connection is required for a rollback. I don’t understand that, but that’s what ATT tech support was told. Pass through is working for me, with a drop now and then. It’s better than nothing, which is what I had before. Disappointed that NETGEAR lied about who pushed the update in the first place. Take responsibility and fix it.
