Jedis
Jul 26, 2022Initiate
Nighthawk M6 Pro MR6400 won't run without battery when tethered to computer
Hello, I recently purchased the Nighthawk M6 Pro MR6400 hotspot. Unlike the MR5200 and MR6500, it does not seem to want to power on without the battery connected when tethered to a PC. I chec...
kym33
Jun 01, 2023Aspirant
The problem seems to be in the way theyre explaining the procedure to set up without battery. Get the unit working normally WITH battery. Plug in the USB and connect to the power supply that came with the unit, its high power especially for this unit. Take the battery out while its running and it will switch to Plug In Power Only and all you have to do is OK the change. It is now set to Power cord use only...
