Jedis
Jul 26, 2022Initiate
Nighthawk M6 Pro MR6400 won't run without battery when tethered to computer
Hello, I recently purchased the Nighthawk M6 Pro MR6400 hotspot. Unlike the MR5200 and MR6500, it does not seem to want to power on without the battery connected when tethered to a PC. I chec...
kym33
Jun 01, 2023Aspirant
The problem seems to be in the way theyre explaining the procedure to set up without battery. Get the unit working normally WITH battery. Plug in the USB and connect to the power supply that came with the unit, its high power especially for this unit. Take the battery out while its running and it will switch to Plug In Power Only and all you have to do is OK the change. It is now set to Power cord use only...
IHaveAHotspot
Jun 01, 2023Initiate
kym33 Now disconnect the cable. Plug it into your computer. Back to "you must plug into our adapter because we withheld information (I.E. lied) in the tech specs about what operating without a battery means. Maybe the MR6550 is different, but removing the battery flashes "power mode change, restarting" and there's no OK to hit. And the "high power" thing sounds like BS since like I said, the connection that supposedly doesn't supply enough power to operate without the battery somehow can supply enough power to charge the battery and operate it. I'm not an electronics/electrical engineer so maybe there's a legit reason, but the idea that being plugged into a computer or other adapter provides enough power to charge the battery and operate it somehow can't provide enough power to just operate it seems improbable. How does that work?
- camperhawkJun 19, 2023Aspirant
The power adapter is the last dirt!!!
I had to press with two fingers the USB-A to power adapter so that a good contact get it.
I've got otherwise loose contact!
Realy weak!!!
