Jedis
Jul 26, 2022Initiate
Nighthawk M6 Pro MR6400 won't run without battery when tethered to computer
Hello, I recently purchased the Nighthawk M6 Pro MR6400 hotspot. Unlike the MR5200 and MR6500, it does not seem to want to power on without the battery connected when tethered to a PC. I chec...
IHaveAHotspot
Jun 01, 2023Initiate
kym33 Now disconnect the cable. Plug it into your computer. Back to "you must plug into our adapter because we withheld information (I.E. lied) in the tech specs about what operating without a battery means. Maybe the MR6550 is different, but removing the battery flashes "power mode change, restarting" and there's no OK to hit. And the "high power" thing sounds like BS since like I said, the connection that supposedly doesn't supply enough power to operate without the battery somehow can supply enough power to charge the battery and operate it. I'm not an electronics/electrical engineer so maybe there's a legit reason, but the idea that being plugged into a computer or other adapter provides enough power to charge the battery and operate it somehow can't provide enough power to just operate it seems improbable. How does that work?
camperhawk
Jun 19, 2023Aspirant
The power adapter is the last dirt!!!
I had to press with two fingers the USB-A to power adapter so that a good contact get it.
I've got otherwise loose contact!
Realy weak!!!
