Jedis
Jul 26, 2022Initiate
Nighthawk M6 Pro MR6400 won't run without battery when tethered to computer
Hello, I recently purchased the Nighthawk M6 Pro MR6400 hotspot. Unlike the MR5200 and MR6500, it does not seem to want to power on without the battery connected when tethered to a PC. I chec...
Alex_Becon
Jan 23, 2024Aspirant
It's understandable that you want to use your Nighthawk M6 Pro MR6400 without the battery while tethered to your PC. While this isn't the typical functioning mode for the device, there are a few things you can try:
Option 1: Enable "Power Cord Use Only" Mode:
Power on the M6 Pro MR6400 with the battery inserted.
Connect the device to your PC using the USB-C cable.
Wait for the device to fully boot up and connect to the internet.
Open the Nighthawk Mobile app or access the web interface at http://192.168.1.1
Navigate to "Advanced Settings" > "System" > "Power Settings."
Look for the option called "Power Source" or "Power Mode."
If available, select "Power Cord Use Only" or a similar option that prioritizes external power.
Verify if the device stays powered on with the battery removed now.
Option 2: Try Different Power Sources:
Ensure you're using the original USB-C cable and power adapter that came with the M6 Pro MR6400.
Try connecting the device to a different USB-C port on your PC. https://reelssaver.net/
Test other power sources like a wall outlet with a high-power USB charger (5V 2.5A or higher).
