Jedis
Jul 26, 2022Initiate
Nighthawk M6 Pro MR6400 won't run without battery when tethered to computer
Hello, I recently purchased the Nighthawk M6 Pro MR6400 hotspot. Unlike the MR5200 and MR6500, it does not seem to want to power on without the battery connected when tethered to a PC. I chec...
JohnPeng
Aug 03, 2023NETGEAR Expert
To use M6 tethering with your laptop, you have to use the battery since the laptop USB port can't provide enough power to use the device without battery. That is why we limit the user to use the device in such way by displaying a image to indicate using PA when no battery is used.
Thanks
John
HenningAugustie
May 24, 2024Aspirant
I am using my M6 Nighthawk in my caravan, and so is one of my friends. We have Both problem to use the router without the internal battery and without the originale 240V powersupply. We both have tried different DC/DC powerconverters 12volt to 5volt without any luck except from two USB powersupplies out of eight USB powersupplies we have tried. We really do need to g’et this problem solved.
kind regards
Henning Augustine
Denmark
- johnnyz59Aug 08, 2024Aspirant
What you need is a device like this, Compact 95W USB USB 3.2 Gen 2 Type-C PD Injector (DFP) w/ 10Gbps Speeds for Seamless Legacy Host to PD Device Connectivity - Coolgear
Almost all hubs with PD only supply that power to the upstream connection and not the downstream connections on the hub. There are a few very expesive hubs that do, but in this case you just need to inject the power to the USB connection used for the tether. That is what this device does. You will need 2 USB-C to USB-C cables capable of PD to connect this to your laptop and the M6. Use the power adapter and USB-C cable that came with the NightHawk M6 to inject the power into this device.
