Jedis
Jul 26, 2022Initiate
Nighthawk M6 Pro MR6400 won't run without battery when tethered to computer
Hello, I recently purchased the Nighthawk M6 Pro MR6400 hotspot. Unlike the MR5200 and MR6500, it does not seem to want to power on without the battery connected when tethered to a PC. I chec...
Jawwadrentacar
Aug 09, 2024Aspirant
Hello,
It seems like the Nighthawk M6 Pro MR6400 operates differently compared to the MR5200 and MR6500 when it comes to powering on without the battery. Unfortunately, some devices are designed to require the battery to be connected for operation, even when tethered to a PC via USB.
Since you've already checked the settings and confirmed they are identical across your devices, it may be a hardware limitation specific to the MR6400. To bypass this, there may not be an option within the device's settings. Rent a car in karachi
However, you could try the following:
1. **Firmware Update:** Check if there's a firmware update available for the MR6400. Sometimes updates can address power management issues.
2. **Contact Support:** Reach out to Netgear support to see if there's an undocumented method or setting that might allow the MR6400 to power on without the battery.
If the device is designed this way, using the battery might be necessary when tethering, even if it’s just for stationary use. If this is a significant concern for your usage, contacting support might be the best step to confirm your options.
Best regards,
[Your Name]
