Racingmacat
May 12, 2023Aspirant
Nighthawk M6 Pro (MR6450)
I recently purchased this, dare I say, rather expensive product & must say that thus far I'm having trouble finding the optimum settings to achieve reasonable wifi coverage either on battery power or on mains power with the battery removed. I have tried connecting the Nighthawk to an eero 6 wifi mesh via ethernet & although a bit cumbersome for anything other than a fixed location, it seems to work quite well.
However, as a newbie to MiFi I would really appreciate any advice on how to get the best wifi coverage, when away from home, from my Nighthawk M6 Pro using just battery power and/or mains power with the battery removed.
I have the MR6110. their range isn't the greatest for their wifi as their a hotspot.
Connecting it to your eero is a great option for better coverage.
You'd want the M6 put in passthrough mode when you connect it to the eero.
- RacingmacatAspirant
Thank you very much Plemans, you comments are much much appreciated.
