awachterberg
Jan 18, 2024Aspirant
Nighthawk M6 pro Mr650 charger not working
Charger stopped working, contacted support and told me out of warranty. It appears this is a common fault with this charger yet Netgear will not back this up with a replacement. Now need to purchase 3rd party charger as I cannot locate genuine charger
Are you asking for help in finding a replacement?
Netgear generally seems to be reluctant to sell replacement chargers and adapters.
Any generic device should work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions. (Look at the label on your device or the old adapter.)In your case, have you ruled out the battery? These generally have a shorter life the chargers.
For better advice, trying asking in the section given over to things like the MR650:
- awachterbergAspirant
Hi, thank you for the response. I have ordered another charger which i hope will be compatable. My main of concern is tha5 it appears that Netgear knows this problem yet not offer replacement.
Albert
Albert
Every company knows that power supplies will fail. Its just most companies will sell replacements if they're not generic.
Your charger for the M6 uses a standard so you can pickup one from anywhere. You might have even had one sitting around from a phone.
