Thomtenh10's avatar
Thomtenh10
Nighthawk M6 Pro
Hello,
I would like to establish Internet access via the M6 for my existing WLAN with the mesh routers. The M6 should have switched off the WLAN and no DHCP server should run there. The mobile access is intended to temporarily replace the omitted cable modem access until the fiber optic connection is laid. Access should be via LAN cable. The M6 should work like a modem.
How do I configure the M6 for this?
Thank you very much for your help
Thomas
  • Hi Thomtenh10
    Welcome to NETGEAR Community!
    Kindly access M6 Web UI, go to Settings > Advanced > Mobile Router Setup
    set IP Passthrough to 'ON'
    checked Ethernet 'Enabled'
    Then connect an Ethernet cable to the M6 and to your existing router.
    Blanca
    Community Team
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Thomtenh10
    Blanca
    Community Team
