jcarthy's avatar
jcarthy
Nighthawk M6 Pro
I am using my M6 pro to connect to my wired network within the network there are two Netgear  switches. When I carry out a speed test using the WiFi the speed is faster than the wired connection.
speed wireless is 50Mbps
Speed wired is 8Mbps
any advice would be great.
thanks.
  • plemans's avatar
    so you're using the M6 to supply your switches? or you're using offloading so the M6 can use the network as internet?
    Unsure of exactly what you're doing.
    did you test the speed directly connected to the M6 without going through the switches.
      • plemans's avatar
        What speed do you get when hardwired into it?
        do you have it set on performance?
