LilReAsoN
Jun 14, 2023Guide
Nighthawk m6 pro(MR 6500) keeps restarting (stuck in a boot loop)
So as the title implies, yesterday my Nighthawk m6 pro has been stuck in a boot loop. if i remove the sim card it will work, but when it is in, it will not work. I went to the ATT store and we replac...
LilReAsoN
Jun 16, 2023Guide
So a small update, I tried turning it on after a day. It worked right away and seems to be going strong. I'll update everyone after a few hours to see if it sticks. To see if you guys can reproduce it, hold the power button and plug in the device at the same time. It should say "downloading update". I did this when I went to bed. In the morning it still said it, do I unplugged it and plugged it back in. And it seems to work now.
