LilReAsoN
Jun 14, 2023Guide
Nighthawk m6 pro(MR 6500) keeps restarting (stuck in a boot loop)
 So as the title implies, yesterday my Nighthawk m6 pro has been stuck in a boot loop. if i remove the sim card it will work, but when it is in, it will not work. I went to the ATT store and we replac...
JDavis40
Jun 18, 2023Guide
What did you do to correct the issue ?
LilReAsoN
Jun 18, 2023Guide
Turn it off. Hold the power button while plugging it in. It should said, "downloading update" . For me I left it on overnight. That being said, I legit don't know what was wrong.
- mrforrestJun 18, 2023TutorI did that as well and it never downloaded... That and it just shut itself off still... They are sending me a new one... Should have it tomorrow
- Blanca_OJun 19, 2023NETGEAR Employee Retired
Hi, All,
We are aware of the issue and we are working on a resolution. We will report back with an update as soon as possible.
Blanca
Community Team- mrforrestJun 19, 2023TutorAre you going to help the ones out of warranty? I have one that this happened to which made me have to buy a new one...
