LilReAsoN
Jun 14, 2023Guide
Nighthawk m6 pro(MR 6500) keeps restarting (stuck in a boot loop)
 So as the title implies, yesterday my Nighthawk m6 pro has been stuck in a boot loop. if i remove the sim card it will work, but when it is in, it will not work. I went to the ATT store and we replac...
franky007
Jun 20, 2023Aspirant
In any case, I appreciate your getting in touch. mynorthsidehr
- JDavis40Jun 21, 2023GuideFirstNet warrantied my device and the new one seems to be working fine for now.
- sjbenderJun 22, 2023Guide
Just wanted to add a couple cents to the thread...
I had issues with my 6500/firstnet earlier in the year where it would lock up under heavy use. When I tried to reboot the unit via software it would just turn off and not back on.
I then updated the firmware in jan and added an external wireless router. One or both of these things corrected all of the issues I was having. Just updated the firmware again to the most recent ntgx65_12.01.16.00 and have not had any issues.
- LilReAsoNJun 22, 2023GuideWhile that might of been an issue, this is a different one where it will turn on but then reboot. Also most people already updated and still encountering it. Now that being said, no one clarified about using an external router. I am the OP and I can say I also use an external router and had it updated. The issue still happened. On that version as well. It has been working for me the past few days, but I'm not sure how it got fixed.
