LilReAsoN
Jun 14, 2023Guide
Nighthawk m6 pro(MR 6500) keeps restarting (stuck in a boot loop)
 So as the title implies, yesterday my Nighthawk m6 pro has been stuck in a boot loop. if i remove the sim card it will work, but when it is in, it will not work. I went to the ATT store and we replac...
LilReAsoN
Jun 28, 2023Guide
So another update. The fix I said worked, but after about 12ish hours it did it again. I did the fix again and it fixed it again. So the fix is somewhat consistent but not optimal.
JT240Z
Jun 28, 2023Luminary
So, what was the "fix" that you implemented?
- LilReAsoNJun 28, 2023GuideIt was said previously in the thread, but ill say it again. Turn off the device. Hold the power while you plug it in. It should say something like "downloading software update" leave that on for a bit(in all three cases I did it when I was asleep). After a bit it will still say updating. Unplug it and plug it back in and it should work.
- JT240ZJun 28, 2023Luminary
So, you telling me that you intentionally corrupt the software download and that fixes the problem? Wow. Another fine example of the issues that Netgear is having with their firmware updates. Makes me wonder just what firmware the device is using then if the firmware update is not allowed to complete.
- LilReAsoNJun 28, 2023GuideIf I'm being honest I don't think that mode does anything. It says that even without the sim. I think it is a safety boot mode thing. Like if you wanted to add custom firmware(but they don't have that on m6) so legit don't know:/. It is on the newest firmware 12.xx.xx.xx whatever it is.
