LilReAsoN
Jun 14, 2023Guide
Nighthawk m6 pro(MR 6500) keeps restarting (stuck in a boot loop)
So as the title implies, yesterday my Nighthawk m6 pro has been stuck in a boot loop. if i remove the sim card it will work, but when it is in, it will not work. I went to the ATT store and we replac...
JT240Z
Jul 06, 2023Luminary
All kidding aside, is there a way to fix a non-warranty unit (locked MR6500) that's doing the boot loop? I can pick one up for cheap and would like to see if it can be fixed long term.
Blanca_O
Jul 06, 2023NETGEAR Employee Retired
Hi, All,
We are working on a firmware update that will address the issue that is expected to be released in 1-2 weeks.
Blanca
Community Team
