LilReAsoN
Jun 14, 2023Guide
Nighthawk m6 pro(MR 6500) keeps restarting (stuck in a boot loop)
So as the title implies, yesterday my Nighthawk m6 pro has been stuck in a boot loop. if i remove the sim card it will work, but when it is in, it will not work. I went to the ATT store and we replac...
sjbender
Jul 09, 2023Guide
My 6500 went offline today at around 1330EST. The unit was running flawless 24/7 for over 6 months until this morning. The unit is over 600 miles away so I can't see if this is the reboot issue and wont be at the unit for two weeks. Major PIA and inconvenience if so.
kaveh_pm
Jul 09, 2023NETGEAR Expert
Its hard to determine the issue however if your unit has been working for a long time with no reboot issue and has been in the same locations, its unlikely to be related to reboot issue, but again its difficult to rot cause that.
Thanks
Kaveh
- sjbenderJul 09, 2023Guide
kaveh_pm I may have been premature in my message. It appears that the solar equipment (ecoflow) has powered itself down. I still wont know for a couple weeks if this is the case. Ecoflow also has a flaw in their latest firmware that once a unit is 100% charged it turns off the AC output... sigh.
- Blanca_OJul 17, 2023NETGEAR Employee Retired
Hi, All,
We got an update from the team that a new firmware (v12.01.16.01) is available to address the constant reboot issue that was introduced in the previous firmware.
Applicable for MR6110 / MR6500 (AT&T SKU)
I. For devices experiencing a continuous reboot cycle, kindly enable Ethernet offloading to check for firmware updates on the Web UI. Please follow steps below:
1. Remove the SIM card and insert a sufficiently charged battery into the device.
2. Press and hold the power button on the top of the device for a few seconds to turn it on.
3. Connect the device to a computer using the USB-C to USB-A cable included in the box.
4. From your computer’s web browser, go to the Web User Interface (UI) of the device at http://attwifimanager. If this fails to load within a few minutes, try http://192.168.1.1. Enter your administrator Username and Password, then click SIGN IN.
5. From the Web UI dashboard, navigate to the SETTINGS tab > General > Internet > click Ethernet + Cellular and Apply.
6. Once the device has finished rebooting, begin physically setting up the Ethernet offloading to the device by determining an available access point to use. In your home, this access point is likely to be the router that you usually use to connect your other devices, such as cell phones and laptop computers, to the Internet.
7. Connect the device to the router using an ethernet (or LAN) cable. Plug in one end of the cable into one of the LAN ports of the router (usually not coloured distinctively and labelled numerically or “Ethernet” or “LAN”) and plug in the other end of the cable into the Ethernet port of the device.
8. On the Web UI, wait up to a few seconds and refresh the webpage to check that the device now has Internet connection via Ethernet.
9. Check for and install firmware updates, go to the SETTINGS tab > Administration > select Firmware Update and click the Check for Updates button.
* Note that you can check for updates only once every 24 hours.
10. The firmware update will start downloading and installing automatically. The firmware update is complete once the device has finished several rounds of rebooting.II. As for units not affected, it can receive the updates over the air.
Kindly go ahead and update the firmware and let us know how it goes.
Blanca
Community Team - sjbenderJul 17, 2023Guide
My 6500 appears to not be one of the ones looping. I did log in and saw that it has a pending firmware update. I selected postpone since I am not near the unit then it stated it will install in four hours... A little nervous here since I will not be near the unit till Friday.
- JT240ZJul 17, 2023Luminary
I guess I'll have to wait for 24 hours since it was just woken up from the "download software" screen and reports last check for update occurred on today's date. Will find out tomorrow. Right now, it's setup in Ethernet offloading mode, connected to my laptop with the USB-C connector, my network Ethernet cable plugged in and waiting for me to check for an update tomorrow. Fingers crossed.
One thing, I noticed is that the WEB App shows firmware up to date and has no provisions to check for updates. If I go to the firmware update screen on the device, it has a check for update button but says "network not currently available, try again later" when I press it. I'm assuming that this is because it thinks it did a software update earlier today.
I did verify that the laptop is connected to the internet through the MR6500 plugged into my router?
- banderson01Aug 11, 2023Tutor
I removed the SIM card and configured the router for Wi-Fi offload. When I click on check for firmware update, it always reports update error, and the firmware does not update. How can I get past the update error?
- banderson01Aug 15, 2023Tutor
Here are screenshots of what I am seeing when trying to update the firmware.
- JohnPengAug 16, 2023NETGEAR Expert
For FW upgrade OTA, you need to have active data connection or do Wifi or Ethernet offloading. Since it is ATT device, I think you need to have ATT SIM and connect to AT&T server first before offloading will work later. You also need to insert a SIM card to the device.
Thanks
John
- banderson01Aug 16, 2023Tutor
JohnPeng you said on 2023-07-17 that we need to enable Ethernet offloading. @Blanca_O also said this on 2023-07-17.
