LilReAsoN
Jun 14, 2023Guide
Nighthawk m6 pro(MR 6500) keeps restarting (stuck in a boot loop)
So as the title implies, yesterday my Nighthawk m6 pro has been stuck in a boot loop. if i remove the sim card it will work, but when it is in, it will not work. I went to the ATT store and we replac...
banderson01
Aug 15, 2023Tutor
Here are screenshots of what I am seeing when trying to update the firmware.
JohnPeng
Aug 16, 2023NETGEAR Expert
For FW upgrade OTA, you need to have active data connection or do Wifi or Ethernet offloading. Since it is ATT device, I think you need to have ATT SIM and connect to AT&T server first before offloading will work later. You also need to insert a SIM card to the device.
Thanks
John
