chris13764's avatar
chris13764
Nighthawk M6 to Brother printer
Having issues connecting my Brother HL-L2305W printer. The my network name does not show up and having issues trying to manually enter it.
Hoping im just doing something wrong or missing something.
Any ideas or a detailed explanation.
Best I found for connecting is this YT Video:
https://m.youtube.com/watch?v=bCJ6DtDEkFg
  • Thats a pretty old b/g/n printer. It might have issues with the new security (wpa3) or even just the new wifi standards.
    Is your M6 on wpa2/wpa3 mixed mode for security? If so, try just wpa2
  • StephenB's avatar
    One option is to connect it with ethernet (assuming it is near the router).
    What are the issues with manual entry?  Would simplifying the network name and password help?
    • chris13764's avatar
      chris13764
      Unfortunately the router is in an out or reach area due to it being directly connected to a security system.
      I figgured it out after reading the above response. Had it set wrong. being that i used all new devices and the printer being the only older device.
      The printer couldnt accept 5g. Which i only had that on and not 2.4g
  • plemans's avatar
      chris13764
      I read this to myself this morning and it smacked me in the face 10 mins later... "old" printer.
      Well... i figured it out. i had the router set on 5g only and not 2.4/both
      I only set it on 5g because im in a small space.
      I knew it would be something so little and annoyingly stupid.
