Aggie83
Dec 06, 2018Aspirant
Nighthawk Mobile stops working
Howdy.
I just replace my old hotspot with a Nighthawk MR1100 and am having an odd problem. The mobile router will suddenly stop allowing the internet connection to devices. The router still shows a...
Aggie83
Dec 07, 2018Aspirant
I will try that tomorrow. The ATT cell tower is our only communication, so if I swap out the sim card to the Nighthawk, I will not have internet.
Also, which IP addresses to I need to check? On my laptop?
Thank you very much. We have owned this for three days. It worked perfectly the first day. On day two, it would only work for a few minutes at a time, but my iPhone still was getting data.
Karen
Mexoh1To7k
Dec 07, 2018Apprentice
The default IP address of the NightHawk is 192.168.1.1.
You can access the web interface via http://192.168.1.1
