Aggie83
Dec 06, 2018Aspirant
Nighthawk Mobile stops working
Howdy.
I just replace my old hotspot with a Nighthawk MR1100 and am having an odd problem. The mobile router will suddenly stop allowing the internet connection to devices. The router still shows a...
Mexoh1To7k
Dec 07, 2018Apprentice
The default IP address of the NightHawk is 192.168.1.1.
You can access the web interface via http://192.168.1.1
Aggie83
Dec 09, 2018Aspirant
Ok. I can connect to the internet only when it is connected to a computer via usb cable.
I can connect tall of my devices to the wifi but it does not have internet access on 2 or 5.
the IP on the router is shown as 192.168.1.1
The wifi is set up as WPA2_Personal_AES
So, the Nighthawk does connect to ATT with the SIM card.
It can 'connect' to a multitude of devices, including laptops, desktops, phones, printers.
It cannot provide internet access to any of them wirelessly.
Broken router? I did not change any of the settings that were default.
This mobile router has been turned off for two days, so a restart will not help.
Please advise if I should return this for replacement.
