JoyMartin's avatar
JoyMartin
Follower
Jul 16, 2021
Nighthawk MR1100 - blinking blue light
The blue power light on the MR1100 mobile router is continuously blinking in a short burst of two blinks.  I searched this site and haven't found a cause or solution.  Today, my connection keeps dropping and reconnecting so I'm assuming it's related to the blinking blue light.  Any insight and/or assistance is appreciated!
  • I just set mine up, it's working fine, and the blue light blinks twice just as you describe.  So I don't think the light indicates the problem.
