reading_na
Mar 07, 2023Follower
Nighthawk MR1100-1TLAUS Firmware Upgrade
Good afternoon , I just did a factory reset on my Nighthawk MR1100-1TLAUS. I am trying to upgrade the firmware to the lastest version ( MR1100-1TLAUS_23113199_NTG9x50C_12.06.02.00_00_TELSTRA_04.04...
JohnPeng
Mar 12, 2023NETGEAR Expert
Please check the FW version on your device. Your device may be on the latest release already.
Latest release:
FW:12.06.08.00; PRI 05.05.
Thanks
- LaoskidoAug 22, 2023AspirantIs there a miss listed source for this Mr1100 1tlaus version on the netgear GPL release ?
Currently, there are 2 files, one for pri 04.04 and other for 05.05
However, both are identical , point to 1 file of downloaded.
Furthermore, the releases on GPL is 12.06.02.00, this is way different than what stated for pri 05.05
Could you please check sir
