reading_na
Mar 07, 2023Follower
Nighthawk MR1100-1TLAUS Firmware Upgrade
Good afternoon , I just did a factory reset on my Nighthawk MR1100-1TLAUS. I am trying to upgrade the firmware to the lastest version ( MR1100-1TLAUS_23113199_NTG9x50C_12.06.02.00_00_TELSTRA_04.04...
kaovn25
Feb 05, 2026Aspirant
Hi everyone,
I recently got a Netgear Nighthawk M1 (Model: MR1100-1TLAUS - Telstra) from a friend. I am looking for a solution to manually update the firmware, as the OTA function is not picking up the latest version.
Device Details:
Current Firmware: NTG9X50C_10.25.01.00
Netgear Initial Firmware: NTG9X50C_10.25.01.01
Target Firmware: I want to upgrade to the latest version NTG9x50C_12.06.08.00.
The Issue: Since I cannot update via the WebUI
My Question: Has anyone successfully updated a Telstra unit from version 10.25.01.00 directly to 12.06.08.00? I have tried manually updated via WebUI but it showed error 16
Any guidance on the correct procedure to force this update would be greatly appreciated.
Thanks!
Feb 05, 2026Guru - Experienced User
kaovn25 wrote:I recently got a Netgear Nighthawk M1 (Model: MR1100-1TLAUS - Telstra) from a friend. I am looking for a solution to manually update the firmware, as the OTA function is not picking up the latest version.
Device Details:
I see a link in this post you could try:
- https://community.netgear.com/discussions/aircard/mr1100-nighthawk-m1-manual-firmware-update---telstra/1949065/replies/1951659
A bit older than you are looking for. But Netgear normally doesn't provide links for carrier-specific products. You could try reaching out to Telstra.
