amdukh
Apr 24, 2023Follower
Nighthawk MR1100-1TLAUS update failure/frozen (need to resolve)
I left the device for a while, today I plug it in charger and power it. it worked fine . it got an alert for a new update . I started updating via chrome browser by my smart phone. My device began an automatic update , the device being frozen in the update. The device remained plugged into the charger the entire time. The screen says “updating device Please do not power off” with a loading bar that has not moved in several hours. I’ve tried removing the battery, pressing the reset button a varying amount of times and length of times, removing the sim, letting the battery die, and hooking up to my pc. No change. Any solution?
SKU: MR1100-1TLAUS
No RepliesBe the first to reply
