rleamon's avatar
rleamon
Initiate
Jun 25, 2018
Nighthawk MR1100 extreme data use, connection problems
Howdy -- I'm using an MR1100 in a vacation home and have a weird problem. As shown on the attached data log screenshot, every few minutes almost exactly 46081.0 KB of data is logged on the account. I...
  • conceptumator's avatar
    conceptumator
    Jun 27, 2018
    That got it!  Guess I just wasn't holding my mouth right or something. :0)  Actually, as dumb as it sounds, I think my mistake may have been in not restarting the MR1100 with the Eero attached.  I was restarting the Eero but not the modem.  Thanks so much for your help - you have a great day.  Hope you get your issue solved soon.  Take care.
