csw219's avatar
csw219
Follower
Sep 02, 2019
Nighthawk MR1100 IPv6 on LAN
I’ve gathered from older posts that, although the Nighthawk M1 supports IPv6 on the WAN side and that you can receive an IPv6 address while connected to it, it does not support IPv6 on the LAN and blocks ICMPv6. This is means that a router attached to the M1 will not be able to provide IPv6 to devices attached to it.
My question is, are there any plans to upgrade the firmware of the M1 to support IPv6 on LAN, and is there anyway to currently get the M1 to provide IPv6 to a router attached to it?
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi csw219
    Welcome to NETGEAR Community!
    Nighthawk M1 mobile router supports IPv6 on LTE/WWAN side. The option has to be configured when configuring APN. On the LAN side, IPv6 is not supported as there is no options to configure it.
    We recommend posting your suggestion on our Idea Exchange board. Our Product Managers review the board for great ideas to be implemented in future releases. Link is https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
    Blanca
    Community Team
