Sandra_l's avatar
Sandra_l
Nighthawk MR1100 SIM Card not installed
Hi,
I kept getting the error message that my SIM is not installed even when it is. I have tried it in 3 different countries with 3 different sims and it’s always the same problem. The service providers are listed on your website as being approved for usage. How can I solve this issue?
Thanks.
  • Was this MR1100 locked to a certain carrier? What model is your MR1100? You can check on its label on the back, after removed the battery.
    • Sandra_l's avatar
      Sandra_l
      It wasn't locked to a specific carrier as I used it twice with 2 different carriers before it decided to pack up. It says MR1100.
      Thank you.
      • W1lliam's avatar
        W1lliam
        Virtuoso
        The SIM slot on MR1100 is microSIM, and if the SIM card you used to test were nanoSIM wit an interposer, then it is quite possible the SIM card not plugged well as the SIM slot is not designed for user to insert your SIM card easily, the contacts in SIM slot might have problem so your SIM card can't be reqcognized.
