mjohnbollinger
Sep 22, 2020Follower
Nighthawk MR1100 Something Unusual On Battery Display
The display shows NETGEAR, then the light in the top right hand corner start to blinking yellow, then blue, then yellow, then blue, then yellow then it quits. Where it first showed NETGEAR now it shows a battery with what looks like a little lightening bolt in front of it and below there appears to be a little clock. Everything has worked well up to now. Then this started happening. I tried taking the battery out for 60 seconds and then putting it back in. That did not help. Please help me with this. I need the Wi-Fi to work. Thank you.
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi mjohnbollinger,
Welcome to NETGEAR Community!
Kindly do a factory reset using the Reset button. Press and hold the Reset button for five seconds. The mobile router returns to factory settings.
Please contact support to better isolate the issue for possible hardware problem.
Blanca
Community Team
