diehummel
Apr 15, 2018Aspirant
NightHawk MR1100 Telstra to Netgear Stock EU
Hello,
does anyone know, if it is possible to flash an Netgear EU firmware over an Telstra Firmware?
I own an telstra device and stuck at firmware 10.16.04.04. I read that there is already a newr version also from telstra, but in here in Austria with "Drei", i don't get an update. It just says, its up to date. :(
Would be great if can be changed to an EU Firmware Version.
thanks
br
Hi diehummel,
If you refer to the link below, It is instructions to manually update your Telstra M1 device.
Please let me know if this works for you. :]
https://kb.netgear.com/000055962/Why-can-t-I-see-data-usage-on-my-Telstra-Nighthawk-M1
- Jason N
- MAGADEGuide
Hi, the OTA server is buged for worldwild.
I don't if it is possible to flash TELSTRA firmware to a EU firmware but if it is possible , i would like to know how to do, it is interesting.
You are a locky guy i'm still in 10.12 version very very very old.
- JasonNNETGEAR Employee Retired
Hi diehummel,
- Jason N
- diehummelAspirant
Thanks!
But 2 days ago, i got the update also with the update button.
However, the new version works much better now :)
br
Hi diehummel,
That's great! I'm glad that you were able to update the firmware and that it works for you! :]
Thank you for letting us know!
- Jason N
