TaraBTexas
Apr 13, 2019Aspirant
Nighthawk MR1100 won’t show for pc
I have a nighthawk mr1100 connected to at&t as a mobile WiFi router all devices see it fine other than my windows 10 pc. I have manually added it as a profile; no change. I can see a phone with a h...
Blanca_O
Apr 17, 2019NETGEAR Employee Retired
Hi TaraBTexas
Welcome to NETGEAR Community!
If other WiFi devices can detect and connect to the network then the MR1100 WiFi function is working. You mentioned that the Windows 10 Computer detects a phone hotspot, what happen if you will select this network? Is it asking for a WiFi password? For isolation, please bring the MR1100 same room where the Windows 10 PC is setup and check if it detects the network this time. Was this working before?
Blanca
Community Team
- TaraBTexasApr 17, 2019Aspirant
Thank you for your response. The problem actually ended up being range. When the router was next to the pc it saw the network fine.
