Deparnieux
Mar 24, 2018Aspirant
Nighthawk MR1100
Went to get on the computer, no WiFi. Turned on the hotspot to see what is the problem, and it says “Updating device, please do not power off” The little progress bar has made no progress in hours. ...
JasonN
Mar 28, 2018NETGEAR Employee Retired
Hi Deparnieux,
I wanted to check in with you and see if the steps JSnee21 have provided helped fix your issue.
Please let us know. :]
- Jason N
