Deparnieux
Mar 24, 2018Aspirant
Nighthawk MR1100
Went to get on the computer, no WiFi. Turned on the hotspot to see what is the problem, and it says “Updating device, please do not power off” The little progress bar has made no progress in hours. ...
Deparnieux
Mar 30, 2018Aspirant
I tried the steps, but sadly they didn’t work. I had to take it in to be replaced. Thanks for the help!
JasonN
Mar 30, 2018NETGEAR Employee Retired
Hi Deparnieux,
Thank you for responding. :]
I'm glad you have found a work around.
- Jason N
