StefD74FR's avatar
StefD74FR
Nighthawk MR2100 - random reboot
Hi
I have purchased a Nighthawk MR2100 4G router 6 months ago and I am now experiencing random restarts from the M2 - I get disconnected and when I look at the LCD screen the modem has re-initialised and goes through the startup process starting with first dot up to 4 before Wifi becomes available again. Not sure if this is important but I usually connect using 4G+. Firmware version is NGTX24_10.17.08.00
Any clues as to what may be causing the issue and what the fix may be are more than welcome!
Thanks
    • Nick109's avatar
      Nick109
      I also felt the same.
      No one answers, the view but say nothing.
      I have the same problem. Mine just reboots everytime without me presing anything.
      I couldn't even setup the device.
  • facing the same issue after the update.. please kindly post back if incase you had solved the problem... thank you
