Knot2Shabby
Nov 06, 2017Aspirant
Nighthawk password reset from factory to one I want to use
Just got home with my new Nighthawk MR100 Mobile Router. Salesrep at AT&T wasn't helpful and I'm having difficulty setting the password from the original "out-of-the-box" to a password I can remember...
JamesGL
Nov 09, 2017NETGEAR Employee Retired
Hi Knot2Shabby,
Are your referring to the WiFi password of the router? If yes, please check page 51 of the user manual.
http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf
Knot2Shabby
Nov 10, 2017Aspirant
Thanks for the link, I'll check it out. My Nighthawk only came with a single page "manual" not having the link you provided.
