Terry12345
Nov 02, 2017Aspirant
Nighthawke M1 - have to reboot every couple of days
I have a Nighthawke M1 connected to a router/firewall via ethernet and have the M1 in bridge mode (or IP passthrough as Netgear seems to call it). All works well for a couple of days then it just sto...
Terry12345
Nov 05, 2017Aspirant
Guess my problem must be truely unique then!
- JamesGLNov 08, 2017NETGEAR Employee Retired
Hi Terry12345,
You can try to reset the device via the reset button and reconfigure it. Check if the same problem after the reset.
page 73:
http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf
- Terry12345Nov 08, 2017Aspirant
Thanks for the reply. However, as per my 1st post, I’ve already performed a factory reset without success.
- JamesGLNov 09, 2017NETGEAR Employee Retired
Hi Terry12345,
I apologize as I thought that you just unplug the power and take out battery when you say reset. For this I would suggest to contact support team as a possible hardware issue.
- pytherNov 10, 2017Aspirant
I have the same exact problem. I've had my modem/router for about a week and experience this same excat this twice. Oddly, I have to power cycle mine twice. As the first power cycle doesn't enable the ethernet port. I got this hoping it would be more reliable than my United Explore connected via usb, but that doesn't seem to be the case. Considering returning mine, not worth the $200.
