Anzeigefehler
Dec 15, 2025Follower
Nigthhawk M6 Pro, 3 networks simultaneously
Hello everyone, Can anyone tell me how to use three networks (2.4 GHz, 5 GHz, and 6 GHz) simultaneously? I am using the Nighthawk M6 Pro. I would really appreciate your help.
Dec 23, 2025Guru - Experienced User
Anzeigefehler wrote:Can anyone tell me how to use three networks (2.4 GHz, 5 GHz, and 6 GHz) simultaneously?
Do you mean using all three from the same client simultaneously? If you do, then that is not possible with WiFi 6e, since that feature requires MLO - a WiFi 7 feature. You'd need support for that feature in both the router and the client.
