thor1470
Apr 21, 2016Aspirant
No Device Attached
I have a MBR1515 that boots up and provides the following lights power - green wireless - blue blinking 4G LTE - blue Signal - blue WPS - green I log into the router and it says I do not hav...
DarrenM
Apr 22, 2016Sr. NETGEAR Moderator
Hello thor1470
Have you tried to do a factory reset the modem you hold down the reset button for 10 seconds and it will factory reset the modem and you will have to reconfigure the modem.
DarrenM
thor1470
Apr 26, 2016Aspirant
I just tried doing the factory restore and afterwards I'm still at the same spot. Any other options?
