thor1470
Apr 21, 2016Aspirant
No Device Attached
I have a MBR1515 that boots up and provides the following lights power - green wireless - blue blinking 4G LTE - blue Signal - blue WPS - green I log into the router and it says I do not hav...
Eagerbecky
Aug 11, 2016Aspirant
I too have the exact same issues, i was hopeing that you found a fix for this sad issue?,
My isp ssays its a problem with my device, i have did a factory reset and entered all the isp data ,and after reboting ,same thig ,no internet ,i am going nuts at this issue, it has worked great for years untill today /any anseers would be so muxh of a blessing for me??Thank You in advance, Eagerbecky
thor1470
unfortunately, no. we had a spare one in reserve that I used to swap out as no solution has been found. the factory reset did nothing and if I swap the sim card into another device it works, so the issue is done to the device itself.
