thor1470
Apr 21, 2016Aspirant
No Device Attached
I have a MBR1515 that boots up and provides the following lights power - green wireless - blue blinking 4G LTE - blue Signal - blue WPS - green I log into the router and it says I do not hav...
DarrenM
Apr 22, 2016Sr. NETGEAR Moderator
Hello thor1470
Have you tried to do a factory reset the modem you hold down the reset button for 10 seconds and it will factory reset the modem and you will have to reconfigure the modem.
DarrenM
Eagerbecky
Aug 12, 2016Aspirant
Hello, i was sorta glad to read someones response to thew same problems??, however, i am clueless in the PC, wireless, and broadband world??, but i have been wondering if it might make any difference??, if i follow what the manual states??, Possible upgrading the modem Module ,? what ever that is ??
or(" updating)" the Firmware in this device?? presently it states in upper right corner of page that its Version V1.2.2.68
and the modem driver version is V1.7, and does any one know what that means , upgrade the module???
i am desperate, to find a fix for this very sad, and heartbreaking problem of mine? , For i moving in a week to the country , and my employer wants me to work from home , and that would of been fine , however with out my Verizon MBR1515 broadband modem , i will be stuck like chuck , since my cell??My next question is , if i were to purchase or find another Netgear MBR 1515 like this one, Will my ll carrier only lets me use a limited amounted of data?, i think maybr about 1Gb Max,will Sim card work in that other unit?? My ISP says my sim card is working and active , I am not a tech savy girl,so any advice, or clues one may give would be a blessing , Thank you in advance,All Eagerbecky/help if you wish me to send more technical data about the units settings , pleasre advise , i am more than happy to give what ever data is needed about this problem, Thanks to all who have read my post ,Eagerbecky
