Daniel84
May 02, 2018Tutor
No Guest Network settings
Hi, I have bought this mobile hotspot in Switzerland and the settings of Guest Network does not appear, is this somehow restrictred for European version?. Any suggestions? Thank you in advance to the...
- Jun 19, 2018
Hi All,
Thank you for your interest on this feature. While NETGEAR does not comment on availability for new features, please post your query or suggestion to this page :
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Blanca
Community Team
Daniel84
May 04, 2018Tutor
This is European Version, I bought it in Switzerland and use it with a Swiss Operator, I dont think the device is locked.
The Firmware version I have is the latested provided: NTG9X50C_12.02.07.00
In the Model dropdown only come to versions US or AU, so I put US, but as I said I bought it in Europe, it came tough also with a UK adapter, so I assume it is a version model also sold there if that helps.
The other data I will not share.
Thank you in advance for your help.
JasonN
May 08, 2018NETGEAR Employee Retired
Hi Daniel84,
Thank you for responding with the Firmware. :] We are still trying to figure out a solution for you.
Is Swiss Operator the ISP SIM card that you use with the MR1100?
Can you please provide your PRI # and SKU # of your MR1100 so we can identify which model your device is?
Thank you. :]
- Jason N
- Daniel84May 11, 2018Tutor
SKU: MR1100-100EUS
- Daniel84May 12, 2018Tutor
Yes the swiss operator is Salt on an unlimeted 4G plan.
- JasonNMay 14, 2018NETGEAR Employee Retired
Hi Daniel84,
I have forward your issue to my internal team. They will contact you as soon as they can for further assistance. :]
- Jason N
- n3tMay 18, 2018Apprentice
Yesterday I bought an M1 MR1100-100EUS from Amazon Germany. After setting it up it installed an OTA update and the device and firmware version numbers are now exactly the same as posted by Daniel84
It does not have any "Guest Network" setting either — where did you read about such a feature Daniel84? It would certainly be nice to have.
- MAGADEMay 19, 2018Guide
Does anyone have some news from internal netgear team for this feature in future update?
