Daniel84
May 02, 2018Tutor
No Guest Network settings
Hi, I have bought this mobile hotspot in Switzerland and the settings of Guest Network does not appear, is this somehow restrictred for European version?. Any suggestions? Thank you in advance to the...
- Jun 19, 2018
Hi All,
Thank you for your interest on this feature. While NETGEAR does not comment on availability for new features, please post your query or suggestion to this page :
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Blanca
Community Team
n3t
May 18, 2018Apprentice
Yesterday I bought an M1 MR1100-100EUS from Amazon Germany. After setting it up it installed an OTA update and the device and firmware version numbers are now exactly the same as posted by Daniel84
It does not have any "Guest Network" setting either — where did you read about such a feature Daniel84? It would certainly be nice to have.
Daniel84
May 21, 2018Tutor
I saw it on this video https://youtu.be/4lIpaJJ6lD8, but it might be only for the ATT model, and as I see now this might onky the renaming of the second wirlesss network either 2.4 hhz or 5ghz which that we can do now... is jut not called guest network.
- MAGADEMay 24, 2018Guide
It is not a GUEST WIFI. A guest wifi is a isolated lan. It is a second lan without acces permited beetwin the 2 lan. It is use to let only a web access to guest but they cannot acces to the web interface or sdcard file, usb hdd drive connected or other stuff like that.
It will be smart to implente that feature in future update.
Jason, have your some news about the bug of wifi SSID personalisation was not memorized after turned off one of the 2 2.4 or 5ghz wifi??
- n3tMay 24, 2018Apprentice
This one annoys me, too: Whenever I make any change on the WiFi main configuration page (e.g. switch between 2.4GHz and 5GHz) the name of the 5GHz network automatically changes to that of the 2.4GHz one with the suffix "_5G" appended. I always have to manually change it back. Why can't the name just be left alone? I want to use the same SSID name for both networks.
(MR1100-100EUS retail version with latest firmware built 2018/03/05)
- MAGADEJun 14, 2018Guide
Hi jason, so have you a planning date to this feature?
