Daniel84
May 02, 2018Tutor
No Guest Network settings
Hi, I have bought this mobile hotspot in Switzerland and the settings of Guest Network does not appear, is this somehow restrictred for European version?. Any suggestions? Thank you in advance to the...
- Jun 20, 2018
Hi All,
Thank you for your interest on this feature. While NETGEAR does not comment on availability for new features, please post your query or suggestion to this page :
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Blanca
Community Team
MAGADE
May 24, 2018Guide
It is not a GUEST WIFI. A guest wifi is a isolated lan. It is a second lan without acces permited beetwin the 2 lan. It is use to let only a web access to guest but they cannot acces to the web interface or sdcard file, usb hdd drive connected or other stuff like that.
It will be smart to implente that feature in future update.
Jason, have your some news about the bug of wifi SSID personalisation was not memorized after turned off one of the 2 2.4 or 5ghz wifi??
n3t
May 24, 2018Apprentice
This one annoys me, too: Whenever I make any change on the WiFi main configuration page (e.g. switch between 2.4GHz and 5GHz) the name of the 5GHz network automatically changes to that of the 2.4GHz one with the suffix "_5G" appended. I always have to manually change it back. Why can't the name just be left alone? I want to use the same SSID name for both networks.
(MR1100-100EUS retail version with latest firmware built 2018/03/05)
- MAGADEJun 14, 2018Guide
Hi jason, so have you a planning date to this feature?
- Blanca_OJun 20, 2018NETGEAR Employee Retired
Hi All,
Blanca
Community Team
