daveym's avatar
daveym
Follower
May 11, 2017
No SIM installed
I am using this USB modem with an AT&T SIM card connecting to a Panasonic Toughbook CF-31 Windows 7 64 bit Enterprise and when I initlally connect the device to the laptop it will connect but after 20 minutes or so the display on the modem shows No SIM Installed. I have tried multiple USB modems but get the same error. Do you think this the actual SIM card failing?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello daveym
    If you are getting the same error on multiple modems then yea I would say its a issue with the sim card.
    DarrenM
