Manitou
Feb 13, 2026Tutor
no software update available
I received a message from Netgear that I should update my MR6450 - Nighthawk M6 Pro mobile router as soon as possible. However, there is no software update available when I request an update through ...
- Feb 24, 2026
Thank you all for your responses and input. The update was rolled out today for my M6Pro. Patience is a virtue.
Feb 13, 2026Guru - Experienced User
Manitou wrote:I received a message from Netgear that I should update my MR6450 - Nighthawk M6 Pro mobile router as soon as possible. However, there is no software update available when I request an update through the device's menu. The current software version in my M6Pro is: NTGX65_12.01.54.00 and is from 12 April 2024.
Are you sure this email came from Netgear?
Firmware for mobile routers is distributed by your carrier (not by Netgear), so you should reach out to them.
